China YEJ Series Brake Motor
#1
Brake Motor
Construction Feature of Brake Motor
Centre height of frame size: 63~225mm
Controller’s power: center height of fram: ≤100mm, AC220V(99v after rectification)
center height of fram: ≥ 112mm, AC380V(170v after rectification)
Power range: 0.12~45kw
TECHNICAL DATA OF Brake Motor
Photos attached
BRIEF INTRODUCTION OF Brake Motor
YEJ Electromagnetic brake three phase asynchronous motor
This series motors equipped with the manfnetic braker on moved shaft end. when the power off the brake disc with press to the motor back cover, then raise the friction braking toque lead to stop the machine, Unload braking time is subjected to the fram size which range is from 0.15-0.45 seconds. the power for braker must work together with the motor. YEJ2, YDEJ2 series motor have wide range of many area like machine processing equipment, convey machine, packing machine, and the machine for woodworking, food, chemistry, textile, architecture, shop etc.
FAQ:
Q: Do you provide samples ? is it free or extra ?
A: Yes, we could offer the sample for free charge but do not pay the cost of freight.
Q: What is your terms of payment ?
A: PaymentChina YEJ Series Brake Motor
website:http://www.kailidamotors.com/three-phase-electric-motor/yej-series-brake-motor/
